Metal sound from the wheel
  • shoppingshzhang
    • Sep 2014
    • 69
    have noticed strange metal sound from the front passenger wheel. It is especially loud when I go over bumps.
    Here is what happens when I knock on it. It only happens on this wheel.
    Any ideas?
    Thanks
  • Hooffenstein HD
    • Nov 2012
    • 1388
    Sounds like a loose gland nut.
    • dnguyen1963
      • Nov 2011
      • 2651
      Why don't you take the wheel off and look?
      • ELVA164
        • 4861
        Yeah, that should be investigated pretty quickly.
        • shoppingshzhang
          • Sep 2014
          • 69
          I took the wheel off and check the linkages. I didn't see anything loose. Any ideas?
          Thanks
          • AndrewBird
            The Mad Scientist
            • 11898
            Bad upper strut mount maybe? Worn ball joints?
            Put the car in the air and grab the tire with one had on each side and try and shake it back and forth. Do the same with your hands top and bottom. Side to side play is like tie rods, up and down is strut mount or gland nut. Both would be control arm ball joints.
