Door Weatherstrip/Seal - what is going on here?
  • turbo55
    • Jul 2014
    • 223
    The weatherstrip seems to be too small for the door frame. If I try to push the corner in then it pops out on the other side. I'm not sure if this is the handiwork of the PO or my weatherstrip shrunk.
    Anyway, anyone know how to fix this? Do I need a replacement or is there something else I can do? Also, I can't find a P/N on RealOEM and ebay seems to be all over the place. Thanks
  • audiquattrot
    • May 2008
    • 3836
    I have a similar issue but not as extreme. Mine is original to the car so I would suspect it just shrank over all the yrs.
    www.instagram.com/snwmble
    #snwmble
    Current:
    '05 BMW M3 - Silver Grey/Imola Red
    '90 BMW 325iX - Sterling Silver/Houndstooth sport(5-speed converted)
    '15 Mini Countryman - Blazing Red/Carbon Black
    Past:
    '01 Audi Allroad - Light Silver/Platinum Saber Black
    '88 BMW 325iX - Diamond Schwarz/Silver sport *Sold*
    '01.5 1.8TQ - Brilliant Black/Nogaro Alcantara ...after 8.5yrs, *Sold* =(
    '90 BMW 325i - Schwarz/Tan sport *Sold*
    '89 BMW 325ix - Diamond Schwarz/Black sport *Sold*
    • AndrewBird
      The Mad Scientist
      • 11898
      Yup, they shrink. Either buy new, or deal with it. You might be able to make it fit better by pulling it off and putting it back on, starting in the corner, stretching it a bit as you go. Try and make the short part towards the front of the car where it is less noticeable.
      • ELVA164
        • 4861
        Another thing you can do is cut it at the bottom of the door and separate it a bit. I did that to my driver's door seal probably two years ago. No added wind noise, no water coming in, etc.
        • AndrewBird
          The Mad Scientist
          • 11898
          In addition to cutting it and spacing it apart, you could slice a piece out of a car from the junkyard and use it to fill the gap.
          • ///M42 sport
            • 3952
            buy these
            • dnguyen1963
              • Nov 2011
              • 2649
              Sometimes, you can use a heat gun to stretch it back out. You'll need to apply some glue in the back of the strip to prevent it from coming out.
              • turbo55
                • Jul 2014
                • 223
                I think I'll give it a shot stretching it back out by heating it, otherwise I'll either get in on that group buy or get a used one. Maybe I'll stick it in the oven for a few minutes then try to get it on quick.
                • ELVA164
                  • 4861
                  Just note that heating it won't stretch it permanently.
                  • AndrewBird
                    The Mad Scientist
                    • 11898
                    This might help:
                    I'd only use it in the corners though. That way if you ever want to take it off, it's not a pain in the ass.
