Fog light relay
    Fog light relay
    Looking at installing fog lights, but my problem is that I cant find anywhere on the web how a late model (318i) fog light relay looks like. I will need this part for sure.
    Do you guys have reference pictures by any chance? thank you
    Originally Posted by mpowerful
    Ive been looking at this thread ever since it got posted and every time I do my peepee tingles a little.
    1991 Alpinweiß Sedan.... mah mistress. <-click :pimp:
    It's a normal 4 pole relay. If you googled "independent fog lights e30" and found the pdf file version, rather than a thread, he would have the actual part number in there somewhere
      Look at your fusebox. Those little orange relays? You'll need another one. The plug for the switch should be wrapped up somewhere near the firewall under the dash. Install two 7.5 amp fuses in fuse 29/30, find your fog light connectors tucked under the valence, and you'll be good to go.
        Yesterday I found this , but I couldn't make out the color of it. Seems sliver or light blue.... <?>
        That is why I was reaching out.
        Part number seems to be 61311380013 for a K8
