I did a bunch of googling and either couldn't find the right words to search it or just couldn't find a similar post but...
I have a 91 325i and from within the HVAC panel is a noise that sounds like something cycling/rotating continuously at a slow speed. A bit like a CD ejecting but not that, I've been jokingly describing it as the gears inside the 6 button MFC for the clock.
It happens no matter what I set the HVAC controls to but it does change pitch when I put the system into recirc. Any ideas?
Also, whenever I have the faceplate in my crappy aftermarket stereo a whistling noise comes through the speakers that varies with RPM. My assumption is that the head unit was just wired in poorly.
Any help would be much appreciated.
