Fuel gauge acting out?
  • shoppingshzhang
    • Sep 2014
    • 69
    Hi so I noticed lately my fuel gauge sometimes gets stuck in full position. Sometimes it works properly and shows fuel level. However, even when the fuel gauge is stuff in full position, the on board computer would show the correct range.
    Would you mean there's something up with the gauge itself?
    Thanks
  • Codym42
    • Mar 2013
    • 611
    It's a common problem. It most likely can be fixed by taking out your cluster and tightening up the ground nut on the back.
    '90 325i - 5 speed coupe
    '05 330ci 6MT ZHP
    • dnguyen1963
      • Nov 2011
      • 2651
      Or the floater in the fuel level sender is stuck. Take the sender out, spray the tube (there should be a couple of small holes) with carb cleaner and shake the floater up and down vigorously. Continue doing this until the carb cleaner is clear.
      • e30onBBSs
        • Dec 2014
        • 1347
        It seems obvious but my friend caught me doing this. When you flip it over, make sure you are tightening the right ground or you are going to put it back in and be like ??. He was like "how do you know it's that side?" And I was like cuz look, flipped it over, that was the wrong side! Screwed the correct one and it worked for me!
        BMW tech
        Umass Amherst
        05 wrx sti
