I just recently finished up my m62 swap and I just hooked my cruise control up today...it worked great with the m10 but now with the m62 it doesn't work.
I checked the connector at the speedo, I checked the brake and clutch switch (the cruise unit clicks when either switches position is changed)...and I checked the belt in the unit.
I finally got it to work, and it held just fine...tried it again later in the day and it accelerated for some reason, then let off and wouldn't work again.
Any suggestions? Also how taunt should the cable be at the throttle body?
