A couple weeks ago I noticed that my left interior turn signal light stopped working. The signal still "clicks" when it's on, just no light blinking. The right turn signal works perfectly. All exterior bulbs still work correctly.
Yesterday I pulled the cluster and switched/swapped the bulbs with no fix. I tried to scrape the metal contact surface but that didn't help either.
This problem is so strange to me because all the other gauge cluster electronics seem to work. I replaced the SI battery a couple years ago and it hasn't acted up since. The only problems I can think of would be a bad ground somewhere, bad relay (it still clicks though, wouldn't it not click or make a loud humming sound if it wasn't working?), bad trace somewhere on the cluster, or bad SI board. (Again)
Thanks for any help!
