Multimeter woes
  • e30onBBSs
    • Dec 2014
    • 1347
    Multimeter woes
    I'm trying to test the amps my fuel pump is drawing, and when I jumped the pump my friend was holding the leads and wasn't getting a reading. I also had a pressure gauge connected to the pump outlet and it got a reading so I know the pump got power during that test. I was like well lets test the battery even tho I knew it had charge. Go to the battery and can't get a reading, and the fuse is good. Is there something else to check on the multimeter?
    And when I jumper it I got 10psi and NO fuel. Bentely says 4.3~ psi is where it should be. It this an indication of a bad pump by itself? 1989 325i m20. I assume there should be fuel in the vaccum line connected to the gauge when I remove it right?
    BMW tech
    Umass Amherst
    05 wrx sti
  • AndrewBird
    The Mad Scientist
    • 11898
    How did you hook the meter up? To measure amps it needs to be connected in series with the pump.
    I'm assuming you are have a no start issue and are thinking it is a bad pump?
    • e30onBBSs
      • Dec 2014
      • 1347
      I think I did it right but correct me if I'm wrong. I got 2 small lengths of decent thickness copper wire, and "tied" them around the male ends on the pump. Then we put those two copper wires in the female ends. Didn't get a reading and also it wouldn't work on the battery when I switched it to 12V. Leads are where they've always been doing tests for the battery
      BMW tech
      Umass Amherst
      05 wrx sti
      • Todd Black 88
        • Oct 2007
        • 3449
        Take the connector off the pump. Jump one pin from the connector to the pump like it would be if it were plugged in. Put one of your leads from your meter into the other pin of the connector and the other lead onto the other pump pin. It should look like your meter is a piece of wire in the circuit.
        Your meter MUST be able to do DC amps, and it must be a meter that can handle the load of the pump.
        Unless you have a DC ammeter. Then you just open the jaws around one of the wires to the pump, making sure its somewhat centered, and bobs your uncle.
        Originally posted by codyep3
        I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
        2001 silver/Blk 325 cabby. SOLD
        2002 325xit Sil/blk. SOLD
        2010 F650gs twin
        • george graves
          • 19996
          Sounds like you hooked it up wrong and blew the fuse in your meter. To measure amps, you must INTERRUPT the circuit, inserting the multimeter INTO the circuit. Not measure across it.
          Originally posted by Matt-B
          • vpilarrt
            • Jun 2006
            • 2096
            Operating pressure should be 43 psi (3 bar = 3x14.7), not 4.3.
            • e30onBBSs
              • Dec 2014
              • 1347
              Thanks for the help! So do I need three leads then? 2 into the female plugs then one to the male end or ends? Would I put the meter across both male ends or just one?
              The amps section has 3 settings and the bentely says it should be 7-8 and the third option is 20 so my meter should be able to handle it hopefully, if it will work.
              I checked the fuse first thing and it seems fine but it could be. Only real explanation of why it just stopped working, it turns on and everything. Thanks for the video I learned a lot!
              I hope my gauge has bar on it too or else I need something else
              Also, should there be fuel in the line when I jump the relay? There was none and it seems like if there is no fuel in the line, directly from the pump, it's not working?
              BMW tech
              Umass Amherst
              05 wrx sti
              • e30onBBSs
                • Dec 2014
                • 1347
                My gauge only goes to 10 psi. Got one from advanced auto, didn't fit. Need to return that. Then I got the cheap one from HF and it only goes to 10 psi. Where do I get a gauge that goes to 100 and fits?!
                BMW tech
                Umass Amherst
                05 wrx sti
                • vpilarrt
                  • Jun 2006
                  • 2096
                  Almost any gauge is going to have some generic size fitting. You'll have to get an adapter to fit if to the 8mm (~5/16") fuel line.
                  Also, an image on how to hook up your multi-meter:
                  • e30onBBSs
                    • Dec 2014
                    • 1347
                    so I need to connect a wire between lets say the left male and female side, then put my leads on both the other ones?
                    BMW tech
                    Umass Amherst
                    05 wrx sti
                    • Todd Black 88
                      • Oct 2007
                      • 3449
                      Here is a drawing my 9 year old just made for you.
                      2010 F650gs twin
                      • e30onBBSs
                        • Dec 2014
                        • 1347
                        Thanks for the drawing kid! +1 =)
                        BMW tech
                        Umass Amherst
                        05 wrx sti
