Need help figuring out wheel hop/shaking issue!
  • GThomas
    • Dec 2010
    • 869
    Hey guys,
    Issue : rear end (seems like both wheels) shake violently under hard acceleration in all gears. Makes a shudding noise but only under load.
    Normal driving is good, but this happens on the gas in any gear, even in 5th if I punch it on the highway.
    It is not effected by turning or bumps.
    What I've checked and fixed:
    Last week the CSB, Tranny mounts and diff mounts were changed, (e30 M3 CSB/ AKG Tranny Mounts, M coupe Diff mount)
    The CSB and tranny mounts were pretty shot, after changing them all of the driveline noise was 90 % lost and we found the u-joint to visibly look okay when changing the CSB. But the shaking under acceleration was still there.
    What I've tested.
    Jacked up rear, both wheels don't seem to have any play at 6-12 9-3, the axles only slide in and out about an inch but nothing side to side. The wheels don't make "wheel Bearing" grinding when i spin them. I swapped two other wheels and tires on the rear and the issue still occurs. A friend driving next to me watched and said the rear wheels was shaking and hopping like nuts under hard acceleration
    Here is what I can think of:
    Axles
    Wheel bearings
    U-joint
    Subframe mounts (PO did AKG Poly about 20K ago though)
    ANY THOUGHTS???
    1991 318is S52
    1987 325i Vert
    1991 325i
    2011 e70 X5
    Need Anything E30? -> http://www.gutenparts.com/
  • wodcutr
    • Apr 2009
    • 2193
    blown shocks on the rear!
    The difference between porcupines and BMWs is that porcupines have the pricks on the outside!
    • GThomas
      • Dec 2010
      • 869
      Yeah, had not really thought of that since the car has been handling okay for autocross and not making any different movements on bumps. I will have a look at them for sure though.
      1991 318is S52
      1987 325i Vert
      1991 325i
      2011 e70 X5
      • Boris3
        • Apr 2007
        • 441
        I didn't see motor mounts in the replacement list above. If the tranny mounts were shot good chance the mm are also shot. Easy to tell when they shear but sometimes they may be gone and just not sheared yet.
        1990 325: track/racecar
        2003 330xi; project car
        2004 330i zhp: civilized car
        • GThomas
          • Dec 2010
          • 869
          Motor mounts are AKG poly swap mounts with only 9k on them, so i doubt its them. and it is noticeably from the rear. The shock is still suspect but i had a friend drive next to me and he said the wheel hops side to side and not up and down.
          1991 318is S52
          1987 325i Vert
          1991 325i
          2011 e70 X5
          • wodcutr
            • Apr 2009
            • 2193
            Maybe your axle nut has backed off!
