wierd steering noise?
  • czag13
    • Mar 2006
    • 300
    so in the last few days i've noticed a wierd noise from my steering. When I left work, I backed out, stopped, and while turnin the steering wheel it sounded like maybe the power steering was struggling. It's a really low deep noise, and it seems to get better after driving the car a while, but wat is it? Is it the power steering pump?
    :(^SOLD^:(
  • yozsi
    • Feb 2006
    • 337
    was there resistance in the steering wheel when it made the noise? if not its probably the ball joints.
    Unlimited Slip Diff's FTW!
    1972 240z Drift,Scca BSP, Scca ITS Car.
    • rede30
      • 4697
      i have to say it. Is there enough ATF fluid?
      • yozsi
        • Feb 2006
        • 337
        lol, im sure he checked it.
        • ummagawd
          • Jul 2006
          • 144
          so outta... curiousity.... what would happen if you put regular power steering fluid instead of ATF fluid?
          • DEV0 E30
            • Oct 2004
            • 8874
            Rack doesn't like it one bit. I did it once and made the rack very noisy in my first E30.
            • lordofthewaters
              • Oct 2005
              • 714
              Plus it'd probably leak all over the place.
              Sarcasm is a body's natural defense against stupid.
              When a man talks dirty to a woman, it's sexual harassment. When a woman talks dirty to a man, it's £3.95 per minute.
              "My mother never saw the irony in calling me a son-of-a-bitch." Jack Nicholson"
              Old age and treachery will always overcome youth and skill.
              • DEV0 E30
                • Oct 2004
                • 8874
                That too.
                • ummagawd
                  • Jul 2006
                  • 144
                  perfect
                  • emi
                    • Jun 2005
                    • 80
                    was it a grinding noise? my borther's front pass fender lining came loose and was grinding against the front of the tire, but only when turning in reverse
                    • matt
                      • 3731
                      Add ATF to the power steering.
                      • ummagawd
                        • Jul 2006
                        • 144
                        mine's making some crazy noises... i know its the power steering because at stand still.. if i try to turn the steering wheel just slightly... it goes "wehhhhhhhhhhhh"
                        I'm looking to get a new PS pump... but I also watned to confirm that the rack itself shouldn't be making any noises?
                        • matt
                          • 3731
                          That's the symptom you'll get if you don't have enough fluid, you've checked it, right?
                          • Jordan325iC
                            • Aug 2005
                            • 1697
                            That happened to my car, it's because the the power steering fluid was gone. Check your fluid levels.
                            '88 325is
                            VP UT of Austin Autoholics
                            BMWCCA 380364
                            • Skoobeesnak
                              • Jun 2006
                              • 132
                              Damn car
                              I am having the same issue. It just started today and the level on the dipstick is full. It sounds like the pump is dry or grinding. Could the hose be blocked or some other thing that could starve the pump? I love this car but it is dollaring me to death.
