Car: 1987 325iC
Problem:
Okay, so I've been trying to get the tach to work, along with the mpg gauge just below it. None of this worked since I got the car. The 13 button obc seems to work, althought it only displays 5.9 avg mpg, which seems kinda low. It was just a little around town driving so maybe that's right.
Steps taken so far to correct it:
Took out instrument cluster to inspect SI board. Discovered the newer style lithium board, but went ahead and replaced the batteries with two externally mounted battery boxes, both of which contain 2 AAA lithium batteries. This was needed to equal the 3 volts of each of the lithium cells. The SI board seems fairly normal, as far as resetting the lights is concerned. One odd behavior though is that the lights never "count down." All four green leds stayed lit for the past 8 months. I then went to the junk yard this past weekend and picked up a cluster. Installed it and couldn't get anything on the SI section to light up, still no tach or mpg gauge. Inspected the SI board to find the standard twin AA NiCad board with the acid leaked out. Soldered in a new remote mounted battery holder and reinstalled. SI section now works, although I don't know if it will "count down." Still no tach.
Problem:
