1988 325iS , going to do a valve adjustment but i dont have a manual.. anyone wanna share what theirs says ? my uncle is the one doing it and he said he needs to know which "??" to turn ? something that it goes in order? haha help me out guys , thanks
valve adjustment
Estoril E36 M3/4/5 | Toledo E53 X5 3.0 | LeMans E90 335D M-Sport
Beat me to it. Still gotta do mine though :(Originally posted by ToplessE30Comment
me 3. How long can someone drive with the valves needing adjustment if that is an issue?Comment
Once you start to notice that they're getting louder than usual, it's time to adjust them. It's really not hard, and it's best to do it with 2 people. Takes about an hour at the most, and it makes a big difference.Originally posted by mtechnikme 3. How long can someone drive with the valves needing adjustment if that is an issue?Comment
You are correct. And for a cold setting, let the car sit overnight.Originally posted by wycococan someone verify , " The Bentley Manual lists the correct valve clearance at 0.30mm (0.012in) with the engine hot, or 0.25mm (0.010in) with the engine cold. In this case, the engine is cold, so I adjust using a 0.25mm feeler gauge. " please ?Comment
That's not entirely true. The clearances can actually get tighter as your engine gets more worn, in which case they wouldn't be getting louder, but they would need to be adjusted.Originally posted by EurospeedOnce you start to notice that they're getting louder than usual, it's time to adjust them. It's really not hard, and it's best to do it with 2 people. Takes about an hour at the most, and it makes a big difference.
My fast says: traction control is for the faint of heart :evil:Comment
Yeah, you're right. I guess after a while, you kind of just know when they need it.Originally posted by Scott314That's not entirely true. The clearances can actually get tighter as your engine gets more worn, in which case they wouldn't be getting louder, but they would need to be adjusted.Comment
