Reading Engine Codes M60B40 Inpa help?
  • GB / John
    • Sep 2013
    • 69
    I did some research and bought an ADS interface chip and wired it to a round connector for the engine. Installed inpa and changed ediabas.ini from OBD to ADS and using my laptops serial port running Windows Vista. When I connect cable to engine and run inpa, turn on ignition only the Battery light on inpa changes to on, the ignition light remains off. I then select e34 engine, and get an error message IFH-0009 No Response From Control Unit, after pressing ok I get another error Apicheckjobstatus: error #95 sys-0005 object file not found.
    Anyone clued up on this, and can offer advice? I only want to see if there are any engines codes.
    E30 318is M60B40 4.0 v8 6 Speed Drift Car Build Project
    Wisefab e36/e30 Lock Kit, BC Racing Coilovers
