an intake mod that works!
  • Jand3rson
    • 37587
    #31
    Originally posted by kencopperwheat
    Originally posted by rs4pro3
    Check out the avatar on the third post. Looks a bit familiar...
    I have already alerted Jordan to it's presence.
    Now is there any real truth to this drilling holes in the airbox mod? Does it really work for something else besides sound?
    • SA E30
      • 1248
      #32
      My airbox is diffderent to ur guys ones, mine, has a metal looking finish to it, not sure if is metal or not, will this mod work with this airbox aswell
      • Jordan
        • 12916
        #33
        Drill bits aren't picky. They will drill wood, plastic, metal... even flesh if made available.
        https://mtechniqueabs.com/
        • SA E30
          • 1248
          #34
          Yeah, I know many a time, I have drilled my fingers, should pay attention to what u are doing.
          • bahnfire
            • 204
            #35
            welp, i have two stock airboxes, i have nothing to lose.
            • Spaz
              Crazy Canuck
              • 2276
              #36
              ahahhaa you sicko :twisted:
              Cam .W '91 325is
              Spaz's 1991 Alpine White???? S52 Build Thread...
              • SA E30
                • 1248
                #37
                Have u guys thought about spraying ur air box silver, cause black attracts heat, and silver deflects it, I have just done this, and it also doesn't look too bad
                • MattE30
                  • 1520
                  #38
                  I really don't think it makes a difference.
                  97 Cosmos M3
                  • Sean
                    • 5793
                    #39
                    Yeah, it's plastic - doesn't matter what color.
                    Usually that theory only works in sunlight - when it comes to just heat, color won't make a difference.
                    - Sean Hayes
                    • SA E30
                      • 1248
                      #40
                      My Airbox isn't made of plastic, it is made of metal
                      • Sean
                        • 5793
                        #41
                        :x Oops.
                        Still the same though. ;)
                        - Sean Hayes
                        • SA E30
                          • 1248
                          #42
                          Oh well it still looks cool
                          • rwh11385
                            lance_entities
                            • 18403
                            #43
                            Owner's mod.
                            $175 Fabspeed product.
                            the most cost effective and simplest air intake modification.
                            more power absolutely guaranteed
                            more sportscar sound guaranteed, with better throttle response
                            Porsche Motorsport Germany quoted + 8 Hp on 964/C2/C4/Carrera Cup/RS America
                            "But why pay $175 when you can get the holes for free?"
                            Porsche 964 Carrera Cup High Performance Airbox. High performance Porsche 964 Carrera CUP style cover lid works with factory 964 OEM airbox to increase cold air flow and improve power
                            Manufactured Airbox covers cut away.......
                            MORE:
                            so what's the deal with the 993 factory motorsound airbox. it looks the same as a regular airbox, but with about 40 holes drilled in it! I see that FabSpeed is selling a hot rod air box cover that is mostly just a factory piece with 90% of the center cut out.
                            For a whopping $35 I found a stock 993 airbox lid on eBay. I spent $4 on the 1.5" cut-out drill bit and went to town. Sat. I cleaned and re-oiled the K&N filter, installed drilled lid and went for a test drive. It's quite nice. Below 4k it sounds the same. Between 4k-5k it gets a little louder and after 5k it roars like a lion. Not sure how this will be for long trips, but on the short blasts, it's a lot of fun - and it was cheap too!
                            I tried a cone filter with an integral bell mouthed inlet feeding the 3.5" stock MAF and lost 5hp. put the stock air box back on and gained it right back. Porsche really did their homework. However, when the air box is vented, the gains are in the 5-7hp range consistantly
                            P93 Motorsound Airfilter Cover - Price : 100 Euro
                            Thanks Rob for the tip off to Porsche airboxes. Good info abounds from that sector. And Yes, I am an addict!
                            • Rob
                              • 8166
                              #44
                              I got bored and pulled the 'horn' from my airbox, sounded a little better, so I think i'm going to drill the shit out of it this weekend
                              BEERTECH
                              • Brew
                                • 3060
                                #45
                                I drilled 10 one inch holes in the side of the airbox facing away from the engine. It sounds pretty damn good. Depending on the gear I'm in, between 3k and 5k RPM's the thing roars. :twisted: I'm pretty confident in saying that mid-range power was boosted a little bit, and throttle response is a tad quicker. Good, cheap, and easy mod.
                                '91 318is
