Walbro Fuel pump... any experience with those??
  • Erick
    Official R3V Drifter
    • 11169
    So I traced everything in my fuel pump wiring and I figure the fuel pump is probably whats bad...... again.
    I am considering buying a new fuel pump, but I realize that the Walbro 255lph pump is significantly cheaper than OEM. Now my question:
    Will I flood my engine with fuel with that pump or does the pump work by only sending the amount required by the injectors/ECU.... maxxing itself out at 255lph?
    And basically..... should I go with the Walbro or man up and buy the OEM pump?
    Thanks,
    Erick
    ..::Support FullOpp::..
    FullOpp Stickers for sale!
    Feedback Thread
  • DaN
    • 1265
    Its a return style system, so the regulator keeps the pressure somewhat constant in the rail, and the rest is returned to the tank. The walbro will work fine.
    • browntown
      • Jun 2004
      • 3524
      e30m3performance has some info on a couple pumps used with the well-cell.
      • LEANE30
        • Apr 2006
        • 838
        where are you looking at purchasing the Walbro from? what's the best price you've found RWDrift? i also have been doing research on the 255 lately
        anyone had a bad experience with the Walbro 255?
        ...what hasn’t been done to an m20 yet?
        m20 Oil Stencil
        • duuuurtymyk
          • Apr 2006
          • 111
          ive had experience with these pumps...i had it on my mazda rx7turboII...excellent product...i do warn you though, with my heavy foot, that thang killed my gas...seeing 3 foot fireballs shoot out of my dual mufflers was priceless though...
          http://www.youtube.com/watch?v=JJ707dGNelg
          ...and slide, and slide, and slide
          • Erick
            • 11169
            Its the rotary's fault... not the fuel pump lol
            As for the pump, I found one locally (ironically for an rx-7 since u just mentioned it) for $70.
            Feedback Thread
            • Sean
              • 5793
              True story.
              A stock 2 rotor with no cats can shoot fire.
              Ask me how i know. :P
              - Sean Hayes
