tie rods
    tie rods
    im replacing my tie rods right now, and i dont have a puller, is there any other way to do this? thanks in advance!
    alex
    Bang on the top of the stud since you are replacing it, or bang on the corner of the actual steering arm with a large hammer, and it will pop out.
    Keep in mind, you can't be a wuss about it, takes a few HARD hits.
      For the outer ball joint, if you're replacing it then whack away on the stud as DaN said. If not, I usually can squeeze a 4" 2 prong gear puller on it.
      If you're doing the inner ball joint as well, I use a pipe wrench on that bad boy. Don't forget locking plates.
        alright i rented a puller for free from autozone and got the outer out easy. the inner is giving me a bit of trouble. i tried a large wrench but it didnt seem to work... i'll keep trying. thanks for the help!
          do i just need a larger wrench?
            I used one of these bad boys.
              Get the right size tool of your choice. I also used a monkey wrench when I did mine. It looks like yours is too big or you're not getting "creative"...
                vise grip got the job done, thanks for all the help guys!
