How do you open the active check control panel ? I tried to and already cracked the screen by the check button lol :x
open up active check control panel ?
FS: Plug n Play Second Trunk Light !
My Parts for Sale Thread~
x 1984 325e 2.7i ~ CastroMotorsport Built x Daily Driven
Tags: None -
You don't. You just get yourself some black electrical tape and cut a nice little square to cover up that goddamn abs light…Originally posted by Andy.BWhenever I am about to make a particularly questionable decision regarding a worryingly cheap diy solution, I just ask myself, "What would Ether-D do?" -
You can just make a jumper for the sensor in the washer tank. Unplug the sensor on the side of the tank, then insert a wire to cross the two pins. Easiest solution I think.Originally posted by Andy.BWhenever I am about to make a particularly questionable decision regarding a worryingly cheap diy solution, I just ask myself, "What would Ether-D do?"Comment
If you never actually plan to fix it correctly, you can cut the wires and just twist them together, and add some electrical tape (all of my fixes involve e-tape). ;)Originally posted by Andy.BWhenever I am about to make a particularly questionable decision regarding a worryingly cheap diy solution, I just ask myself, "What would Ether-D do?"Comment
