AC not getting any colder
  • 91318is
    • Aug 2013
    • 168
    After doing the R134A conversion (new condenser, all seals, replaced evaporator, expansion valve, and drier) my AC won't get very cold. There are no leaks and it holds 40psi of refrigerant in 80 degree weather. The condenser fan works and from what I can tell so does the condenser since it still gets a little cold, maybe 60 degrees or something. The only thing I can think of is the switch on the drier was not changed, but I am not sure if that is needed. I followed a few write ups on here and did everything including the PAG oil and all that. The temp does go down a bit when I get the engine to a higher RPM, but not nearly what others have claimed. Any help is appreciated!
    P.S. I bought another can of R134A and it won't allow anymore to go into the system.
  • Klug
    • Sep 2011
    • 804
    If your getting power to the compressor- the switch isn't faulty, as power needs to flow through the switches to enable the compressor to turn on down the line.
    Have you had the system vac'd down? I'm thinking this because maybe there is some gunk/rust floating around and it might have hit the evap valve and blocked it up and it stopped it doing it's job. Just a thought.
    What is your high/low pressure readings?
    555Garage - Kingston, PA
    '13 BMW e70 X5 35d
    '95 BMW e34 525i
    '92 BMW e30 325i S52 Vert (Quade the Vert)
    '92 Range Rover Classic
    '90 Range Rover Classic
    '89 BMW e30 325i Coupe (The DIRTY30)
    '81 VW MK1 Rabbit Caddy Diesel
    '76 Honda CB550K Cafe/Brat
    '67 Pontiac LeMans
    '24 Model T Depot Hack
    ....And a bunch of Motobecane, Puch, Garelli, Batavus and Honda 49cc-78cc Mopeds...
    • efficient
      • Feb 2012
      • 3312
      If you don't mind me asking how much did you spend in total for all new parts?
      • Klug
        • Sep 2011
        • 804
        Check out my post from doing my 100% R134a conversion. Since I got the compressor at a pick-and-pull, total parts was around $250 for the new condenser, dryer, custom lines, evap valve, r134a and HF gauges.
        '13 BMW e70 X5 35d
        '95 BMW e34 525i
        '67 Pontiac LeMans
        • 91318is
          • Aug 2013
          • 168
          I spent around $250 as well. Including the condenser, valve, drier, seals, used/tested evap, R134A and PAG. Wasn't too bad. At highway speeds it keeps me from sweating, just not that cold blast you should get when you start the car and at idle.
          @klug, I will have to check out the high pressure reading. My low is about 40psi and for some odd reason I cannot get anymore into the system.
          My secondary belief is my condenser fan. The previous owner had a odd one in there that seems fairly small and it is about 1 inch from the condenser itself. I am thinking of getting a 90's 750i fan seeing that they have worked for other people. Only issue I have now is my bumper won't come off!
          Thank you for all the replies. I will try to upload some photos/more info soon.
          • 91318is
            • Aug 2013
            • 168
            @Klug Sorry one more thing, I didn't have the system vacuumed but the evaporator, all the lines, expansion valve, condenser, compressor, and drier were all out. Maybe I should have vacuumed the system anyways.
            • steve68
              • Jan 2013
              • 457
              yes!!!!^^^^^^
              88 M3 Lachsliber glass top, 90 IS project,
              • LJ851
                • 7919
                Not maybe, definitely.
                It does not work without pulling a vacuum on the system before filling it with the correct amount of refrigerant.
                Lorin
                The M30 is God's engine.
                • CorvallisBMW
                  Long Schlong Longhammer
                  • 13039
                  OK, stay with me here because this is going to get just a bit technical:
                  R12 has a higher boiling temperature than R134a. This is important.
                  The job of your condenser is to condense the pressurized vapor coming from the compressor back in to a pressurized liquid. Depending on how large or efficient your condenser is, it might be able to convert 100% of the vapor in to liquid, or maybe just 50%. Since R134a has a lower boiling point than R12, the condenser's job becomes more difficult. As an example, let's say the condenser is sized by the mfr to get R12 vapor from 80C to 40C (at a given pressure) in order to condense it fully. Now with R134a, it has to get it from 80C to 30C because R134a boils at a lower temp. This is a 25% larger delta (difference), meaning the condenser has to do 25% more work. It's therefor not able to convert 100% of the vapor in to liquid. When the now vapor/liquid mix hits the expansion valve, the portion of the mix that is liquid flashes to vapor and cools, but the portion that was still vapor does not, meaning less overall cooling effect.
                  Essentially any time you convert from R12 to R134a, your condenser becomes undersized. It's not because of anything you did/didn't do, it just is. There's also the fact that R134a has a lower specific heat (less ability to hold energy, i.e. cool) than R12, so it is less efficient. Most R134a systems are 20-30% larger in both component size and volume than a comparable R12 system to account for this loss in efficiency.
                  The #1 thing you can do when converting to R134a is to do it properly (which it sounds like you have with all new parts) and to make sure the system is fully evacuated before filling (which has already been mentioned). If there's any air in the system as you fill it with R134a, that air will take the place of what could have been refrigerant, and will further hurt the system efficiency (air also contains moisture which also hurts efficiency). Hence why it's important to take the system in to a vacuum and then fill it with R134a, so that you get the maximum amount of pure refrigerant possible in to the system and not a mixture of air/R134a.
                  Long winded I know, but sometimes it helps to understand the mechanics behind it :)
                  • pandaboo911
                    • 2070
                    1. Check for leaks with UV dye
                    2. evacuate and recharge
                    3. run aux fan on high speed instead of low speed
                    4. Profit / bob's ur uncle
                    • 91318is
                      • Aug 2013
                      • 168
                      Thanks Corvallis and Pandaboo. I was thinking the same thing. The previous owner had a different aux fan on the car and it is fairly small even compared to stock. I am going to be putting a faster/larger fan on the condenser and that should help a bit.
                      • 91318is
                        • Aug 2013
                        • 168
                        Not sure what to vacuum. They were all brand new parts and everything was out of the car (including lines). The system works, it just won't get down to freezing temps like I see a lot of people posting with modded systems. I don't think a vacuum is really going to help my cause since the system runs fine, doesn't overheat the car, gets down to 50-60, and most parts were brand new when installed. However if a larger condenser fan doesn't do the trick, I will vacuum out the system as a last resort. A larger fan won't run much a wrecking yard.
                        • LJ851
                          • 7919
                          Any time the system is opened for any reason it must be vacuumed before you add refrigerant. If it was optional, your system would be working well now which it is not.
                          I can't tell if you understand what is being told to you. This isn't vacuuming like you do to your carpet.
                          Pulling a vacuum on the air tight system removes all the air from the system and lowers the boiling point of the contaminants in the system so they will vaporize and can be removed under vacuum.
                          Any air or contaminants left in the system when you add refrigerant will greatly reduce the cooling capacity of the system. This is where you are, and precisely why you need to vacuum the system.
                          It's like eating a steak dinner without chewing. Yeah, you might get it all down but shit it doesn't work very well.
                          Lorin
                          • pandaboo911
                            • 2070
                            Dude without a vacuum 10-20% of your refrigerant will be air, which doesn't refrigerate.
                            It's not expensive to do.
                            • 91318is
                              • Aug 2013
                              • 168
                              Ohh ok thank you guys. Sorry, wasn't reading very well. I am going to go ahead and get it vacuumed out soon. I will post results, sorry for the "stupidness" lol.
