wipers dont work
  • mitch500
    • Jan 2006
    • 1092
    wipers dont work
    so it started pouring yesterday, i went to turn my wipers on and nothing happend, no sound or no attempt to even move. so is this electrical or is the motor just toast. and how do u get the motor out if it is that.
    1988 e30 alpine white vert 5speed
    1987 e30 325 eta
    1983 e28 533
    2001 x5 4.4l
    1997 e36 M3 Alpine white 5speed
    1991 Jeep XJ I6 4.0
  • haledj
    • Jun 2006
    • 48
    it is a bitch, I have done it twice.
    Ok you have to remove the vent by the Drivers Side wiper then remove the pannel at the back of the engine bay and the A/C fan and its housing, then you can get to the wiper linkage and motor, check to see if it has good conections and ground, and see if it runs without being attached to the linkage. If It doesnt get a new motor, If that d/n work then check the fuse (just kidding do that first)
    --Doug
    [/URL]
    • Brew
      • 3060
      Check the fuse first, and then make sure you have power and ground at the motor.
      '91 318is
      • Garageaholic
        Freestyle Fabricator
        • Dec 2005
        • 5204
        if not,, then the motor seized.. that happened to mine... needed to get a new one from the junkyars... as haledj said.. it is a bitch to change... so much shit needs to come out. lolol
        Recent Rebranding!!
        E30 SM62/S62
        E30 M60 V8
        E30 M30 Big 6!
        Instagram.com/garageaholic
        Youtube.com/garageaholic
        • mitch500
          • Jan 2006
          • 1092
          allright i will check that out, thanks boys.
          1987 e30 325 eta
          1983 e28 533
          2001 x5 4.4l
          1991 Jeep XJ I6 4.0
          • kailuaboy
            • 54
            verify that the switch is working first before you pull the moter.
            • mitch500
              • Jan 2006
              • 1092
              yeah i got my bentley manual, so im sure i will trace it to the source this weekend.
              1987 e30 325 eta
              1983 e28 533
              2001 x5 4.4l
              1991 Jeep XJ I6 4.0
