Speedometer problems
    When accelerating, my speedometer goes to 0 mph, but when I let off, it jumps to my actual speed. What's with this?
    97 Cosmos M3
    You might want to check your speedo cable (if these cars have one)
    I had a Blazer that had the same prob, changed the cable, and it was fine.
      Re: Speedometer problems
      most likely a bad speed sensor, its bolted to the diff, i don;t know of any test for it, but that sounds like what is is.
      *btw, our cars use a magnetic pulse sensor on the diff that senses a magnet spining around the ring gear in the diff, to obtain the correct speed.*
      Cam .W '91 325is
      Spaz's 1991 Alpine White???? S52 Build Thread...
