I replaced the gears on my VDO cluster, but after several attempts of messing with the gears and tightness of plastic clear cover, it still does not work.
The other day I found a cluster from a junkyard that came from an automatic. It's a VDO. Although my cluster is for a manual, is it possible to switch the speedometer out without any electrical problems? Will values read different when driving? Will it read higher than normal mph?
Thanks
Thanks
