metal hitting the floor over bumps
  • jasonbk
    • Aug 2011
    • 555
    Hey guys,
    I recently noticed knock/clunk(sounds like metal piece is hitting the floor) when I hit small potholes or go over harsh bumps. It's coming from the floor and I can feel the impact through gas pedal and through my ass as well.
    I went underneath and tried to find if anything was loose but everything felt tight - suspension, shock, exhaust, etc. Any other areas that I should look closer?
  • glnr13
    • 1334
    did you check your front and back suspension?
    check your transmission mounts and cross brace too.
    • jasonbk
      • Aug 2011
      • 555
      Yeah, front and back suspension was tight when I checked few days ago.
      transmission mount seemed tight without any crack but I can't really get a good look at the subframe.. I'll double check when I can.
      • 330SMG
        • Feb 2007
        • 172
        Very well could be your exhaust, specifically the catalytic converter hitting the heat shield. Shake it up and down and you will know rather quickly.
        1989 Cirrus Blau coupe Racing Dynamics wheels and a Volvo Spoiler.
        • jasonbk
          • Aug 2011
          • 555
          Thought I'd report back. It was slightly loose transmission mount bolt. Bolt it tight and it went away.
