car in question is an 89 325i with an obd 1 s52.
so when i first bought the car the cruise was not hooked up, but it didn't take long for me to change that. well it would work about 50% of the time. whenever i would hit a bump it would disengage or sometimes it would work for a minute then just quit.
about 2 weeks ago i was sick of it and decided to try and get it working. well i replaced the brake light switch and boom it was working 100% for about 4-5 days. no brake light led lit up on the check panel. i was golden. then for some reason the brake light warning came back and it hasn't worked AT ALL since.
yesterday i verified that the brake switch and clutch switch are both being depressed until the pedals move then i swapped out the old bulbs (which didn't have any corrosion) and i swapped out the old fuses in spots 6,10,12, 21 and 27 and that took care of the brake light warning on the check panel but still no cruise...
any ideas?
_______________
any ideas?
_______________
