So my 318is decided to nom on its rear brake sensor harness. Of course not the easily replaceable part either. It is the section of harness that passes through the body of the car into were the rear seat is.
Easiest way to explain it is you have your brake sensor wire which goes to your brake pad. Then on the other end it connects to a connector attached to the rear sub frame. From there it passes through the body of the car with a largeish rubber grommet and on to the rest of the harness. What I need is the section that passes through the body of the car with the grommet to the connector. would anyone possibly happen to know the part number for that.
Thanks for any help
Thanks for any help
