Ignition power to gauges?
  • e30onBBSs
    • Dec 2014
    • 1347
    I installed an oil pressure gauge using the oil switch wire and it works fine, but where else is there easy power to grab off? I want to put in an oil temp too. Thanks r3v
    BMW tech
    Umass Amherst
    05 wrx sti
  • efficient
    • Feb 2012
    • 3312
    Window switches, not sure though
    • staysideways
      • Dec 2013
      • 373
      Stereo?
      1989 E30 325i Sedan Alpine
        The simplest way is to used the switched aux fuse on the front of the main fusebox. The box has a switched and unswitched fuse and is intended to be be used for aftermarket add-ons.
