Hey r3v, if you open your hood and are looking at your thermostat from above, there are 2 bolts, not the 4 that connect the housing to everything, but 2 on top that supposedly keep the coolant in. If anyone can tell me what size those are or any other info, it'd be greatly appreciated. Thanks!
E30 Thermostat Question
M20B27 engines (ETA) have four ports in the top of the thermostat housing for sensors. M20B25 engines have two ports for sensors. the current replacement part for the housing has four ports as that works on either engine. When using it on an M20B25 you plug two of the ports. I think the plug ia a short 14mm bolt.The car makes it possible, but the driver makes it happen.
