Removing the Gas pedal...
  • BS87
    • 1606
    Ok, is there any trick to removing the gas pedal? it looks as if on the top of the linkage the plastic pedal connect to the linkage through a round peice. IE on the pedal there is a circle, and on the linkage a cylinder...Any special trick to getting this to come apart?
  • BS87
    • 1606
    Soo i guess noone knows how to take the gas pedal off.... *grabs a pair of pliers*
    • Jordan
      • 12916
      taking the cclip off on the top is easy, getting it out of the base is a bitch.
      use a flathead and push the tabs in.
      https://mtechniqueabs.com/
      • BS87
        • 1606
        Thanks Jordan. I couldnt exaclty tell what was holding the top on, but a clip shouldn't be too hard.
        Much appreciated.
