My 91 318is has central lock. Sometimes when I go to lock or unlock from the passerger side door, the lock doesn't want to turn. However if I go play with the driver's side and come back to the passenger side it will work with no problems at all. Do anyone else have this similar problem? Does anyone know a fix for this?
question about central lock
I dont know if this is the case, but when I turn the key in the drivers side door to lock it and pull the key out (as in not turning it to the original place I stuck the key in....more clearly...when the lock is in this position (---) not this position ( I ) ) and try to unlock the doors from the passenger side, it will only unlock the passenger side door, not all of them. On the other hand, if the lock looks like this ( I ) then I can unlock both doors from either side (passenger of drivers).
HTH
Aaron
Originally posted by aaron_silvaI dont know if this is the case, but when I turn the key in the drivers side door to lock it and pull the key out (as in not turning it to the original place I stuck the key in....more clearly...when the lock is in this position (---) not this position ( I ) ) and try to unlock the doors from the passenger side, it will only unlock the passenger side door, not all of them. On the other hand, if the lock looks like this ( I ) then I can unlock both doors from either side (passenger of drivers).
HTH
Aaron
Thats the "double lock" feature, its kinda like a dead bolt for the drivers side door. If you lock the drivers side by turning the key to the (---) position and remove it, that activates the double lock. The only way to unlock the door is to use the key again on the drivers side door and return it to the ( | ) position.
'05 E46 M3 Imolarot/Cinnamon - CURRENT
'98 E36 M3 Estorilblau/Dove - SOLD
'90 E30 M3 Brilliantrot/Black - SOLD
SRS BSNS Motorsports - 24hrs of LeMons Racer
Originally posted by Jonathan 90 M3Thats the "double lock" feature, its kinda like a dead bolt for the drivers side door. If you lock the drivers side by turning the key to the (---) position and remove it, that activates the double lock. The only way to unlock the door is to use the key again on the drivers side door and return it to the ( | ) position.
Rob, before my keyless entry, I also used the trunk due to the doors locks being too stiff.
Aaron
Originally posted by KenyonRight now to lock and unlock my car I have to use my trunk. About a month ago I tried to unlock my car from the driver’s side, and it wouldn't budge. So now I am using the trunk to lock/unlock my car until I figure out what I need to fix or replace.90 325is
IE stage 3s and refeshed m20....
