'87 325E richness / Oil issue
  • trapical
    • Sep 2015
    • 53
    So my '87 325E is currently running rich.
    I've got these on the way in the mail since I'm unaware of when they were last fixed, or if ever:
    - AFM ( current one was tampered with on the adjustment )
    - Intake boot
    - o2 Sensor
    - Coolant sensor
    - New coolant
    - NGK ZGR5A plugs
    - Oil & filter
    - Cap & rotor
    - Will be cleaning ICV
    But beyond the rich issue, I've noticed when I pull my dipstick that it smells of gasoline. I'm not sure why ( I'm still new to all of this ) so can someone please chime in on what this may be?
    Checked my fuel pressure and that's fine. Pump is working. Have yet to try checking my injectors for leaks though.
    I'm hoping that in a perfect world that it will go away when my richness issue is resolved, but I'm sure that won't be the case.
  • dnguyen1963
    • Nov 2011
    • 2651
    If you smell gas in your oil then I would definitely check for leaky injectors. Your piston rings might be worn too.
