Hesitation and stutter under acceleration
  • kmushu
    • Aug 2014
    • 36
    Hey guys,
    Last week my '89 ix started stuttering at random times while driving. It seems to be only under acceleration and it'll bog down like crazy, even to the point of not being able to accelerate at all. Then it'll kick to life and drive fine. The anti-lock light will come on while it is having trouble but turn off when it clears up.
    Was thinking about pulling the injectors and cleaning them, but any other ideas what it may be?
    Sent from my XT1049 using Tapatalk
  • BMWManiac
    • Dec 2010
    • 1091
    First, make sure your power/ground cables on your battery are tight! Make sure your engine ground is fine....mine is on the driver's side, not sure about the IX
    1997 Artic Silver M3
    CES GT4094r 651hp/615tq @ 24 psi
    • 101
      • Jul 2011
      • 764
      Originally posted by kmushu
      Hey guys,
      This leads me to believe that the ABS warning light and the check engine light are in the wrong positions in your cluster.
      Search "stomp test" and see if there are any codes coming form the ECU. That's about the best place to start the diagnosis.
      101
      The E30 collection:
      1987 325es M52 - Schwarz / Taurus Red Sport (son #2's)
      1987 325is - Delphin / Black Sport (son #3's)
      1987 325i Convertible - Triple Black
      1989 325iX Coupe - Diamondschwarz / Black Comfort
      1990 325iX Coupe - Sterling Silver / Grey Sport
      1981 Fiat 124 Spider 2000 - Green / Tan
      1998 Volvo V70 GLT - White / Tan
      1998 Volvo S70 T5 manual - White / Taupe
      2001 Ford Windstar - Silver / Grey (parts hauler)
      2006 Lexus GX470 - White / Tan (tow rig)
      • kmushu
        • Aug 2014
        • 36
        101, is the check engine light the stand alone behind the cluster? Pulled it and there's only one bulb not mounted in the PCB so I'm assuming that's it.
        Bmwmaniac- will check asap
        • 101
          • Jul 2011
          • 764
          If you mean a bulb that is wired separately from the cluster printed circuit board, there's two "stand alone" lights in the cluster. The check engine light and the ABS light. It sounds like the check engine bulb might be incorrectly inserted into the ABS hole in the cluster. Both will come on when the key is turned to the "on" position and will go off once the engine is started.
          Besides the stomp test and loose grounds, check for a torn intake boot, loose connections at the air flow meter, crank position sensor and coil. It could be a lot of other different things as well that are causing your issues, but start with the easy stuff.
          101
          The E30 collection:
          • kmushu
            • Aug 2014
            • 36
            Thanks guys. Stomp test brought back 1251, injector 1. Going to pull and clean today.
            • NardusDC
              • Jul 2013
              • 76
              I'm having a similar
              issue on my 92 vert. Did you find a solution?
