How to change ignition switch?
  • smabedo
    • Oct 2015
    • 3
    How I'm supposed to change ignition switch without a key? Car is E30 , year model 89.
  • spdracrm3
    • Sep 2009
    • 959
    the switch is considered the electrical part which you can change as long as you can get steering wheel and column covers off (two small screws hold it onto back of lock assembly). to replace the lock tumbler the part key goes into you'll need the key to be able to turn to first position and insert pin into hole to release tumbler . if not you can try to drill it out just be careful not to damage the carrier assembly ,if unsucessful you need to find a good carrier used with a key ,or purchase new from BMW
    Angus
    88 E30M3 X2
    89 325IX
    92 R100GS/PD
    • smabedo
      • Oct 2015
      • 3
      I think that i have to try drill it out but next chance to do it is next weekend.
      • SmokeE30
        • 1730
        just a thought, by next weekend bmw can sell you a new oem key cut for the vin for the price of a steak dinner.
        Shawn @ Bimmerbuddies
        Bimmerbuddies LLC
        717-388-1256
        2971a Roundtop Rd, Middletown PA 17057
        bimmerbuddiesllc@gmail.com
        • 5Toes
          • 9836
          I drilled mine out when a key from the dealer did not match my ignition tumbler. Took about 5-10 minutes
          metal shavings will go everywhere, set a towel down to catch them
          I used the same size drill bit and lots of cutting oil, you can hear each tumbler individually breaking, all 5 of them. take breaks in between each one to apply more oil.
          remember to use even pressure and go slow
          • smabedo
            • Oct 2015
            • 3
            What size was your drill bit?
