ac blower issue
  • hornyboy30
    • Aug 2015
    • 16
    ac blower issue
    Just put in a brand new Blower motor and fixed the resistor, it blows air on all 4 speeds. The only problem is it still makes a sound because once it turns on, the blower motor itself rubs up against the walls even after adjusting it correctly. It seems to move itself once i put it on the highest setting then has a rubbing sound thats kinda loud. If i hit the panel that covers it it seems to be intermittent. Any idea on how to get it to stay in place firmly? I have the band around it that holds it in place and the cover on.
  • ST1G
    • Oct 2012
    • 6689
    Is the band the stock metal band that is suppose to hold it in place?
    • hornyboy30
      • Aug 2015
      • 16
      yes it is
      • modernist
        • Apr 2014
        • 283
        If it's rubbing, it's not adjusted correctly. That band is a pretty tight fit.
        1986 327i
        transaction feedback
        DIY thing
        meh
        • hornyboy30
          • Aug 2015
          • 16
          it is in tight it just changes when I change the settings. The band is securely wrapped around and it spins freely then it randomly rubs depending on setting.
          • ST1G
            • Oct 2012
            • 6689
            So it's not in tight.
