New front bearing nuts?
  • spanish pants
    • 294
    Greetings all,
    The new FAG front wheel bearings i ordered just arrived. I took a quick look to make sure everything was in the box and noticed that the nuts do not come with the little lock tab.
    I´m a little weary of installing the bearing without the locking tab.
    Has anyone encountered this issue with new bearing kits?
    My new E34 525i Sport Limousine Blog
    http://bmw525isportlimousine.blogspot.com.es/
  • goarmy
    • Nov 2011
    • 622
    from ordering many before, I always had to order separate the lock ring, ect
    • spanish pants
      • 294
      Thanks goarmy.
      It looks like all of the nuts sold separately from the kit don´t come notched either. Maybe they expect you to cut the notch yourself ?
      • AndrewBird
        The Mad Scientist
        • 11898
        It's built into the nut. The "tube" sticking out the front of the nut gets hammered into the notch in the spindle with a punch.
        • ELVA164
          • 4861
          This. Just did both of my front hubs and the ones I got from Guten (Optimal) came with the nuts. Hammered the collar in like Andrew says.
          • spanish pants
            • 294
            Thanks ELVA164, AndrewBird,
            I was thinking dremel a notch but your suggestion is less complicated.
