Ate or Gerling Brake Booster?
  • e30 gangsta
    • 3877
    When i turn off my car i hear a hugh hiss. Like a rediculos vacum leak. I pump my brakes and it goes away. I belive i have a leaky booster. I would like to order a new one for the upcoming track day. How do i figure out if it's ate or girling ,and what else should i replace once im in there?
  • browntown
    • Jun 2004
    • 3524
    My booster has an ATE sticker on it.
    • e30 gangsta
      • 3877
      Where's this sticker located? Does it matter what company I get?
      • browntown
        • Jun 2004
        • 3524
        mine has the ate sticker on the face of the booster, I've seen girlings with the sticker on top of the booster like this:
        • Mike325
          • Mar 2006
          • 3685
          Are the ate and girling boosters interchangeable? I had an ate, but now I have a girling off of the same year and model of my car. I am guessing they are interchangeable but not sure.
          Anyone know?
          Originally posted by Kershaw
          • Jean
            • 18228
            I would like to know this too, does the booster need to match anything else in the system (calipers, brake master cyl??)
            • Rocla
              • 922
              They all intercahnge and work.
              Biggest difference is that different engines have vacuum hose in different location, so the biggest mod you might be doing is shortening/lenghtening vacuum hose.
              Current:
              BMW 320i 2d 2.0 m20 -88
              BMW 325i Cabriolet 2.5 m50 -88
              BMW 316i touring 1.6 m40 -90
              BMW 320i 4d 2,2 m54 -01
              • SpunkyE30nOk
                • Jun 2006
                • 228
                I have an ate MC/booster with girling calipers all the way around...don't know how but thats the way i bought it, I haven't had any brake issues...just be sure to use super high performance german blue or gold brake fluid that stuff is awesome
                  The hiss could be from the booster, or it could be a bad check valve or bad hose. You can test the booster to see if it will hold a vacuum by clamping the vacuum line to the booster while the engine is idling. Then wait a minute or so and see if there's still boost (normal brake pedal). It there is the leak isn't in the booster. Alternatively you can use a vacuum pump and gage to directly test the booster.
                  • e30 gangsta
                    • 3877
                    got more info on how to test this?
                    • Rocla
                      • 922
                      Take the vacuum hose off from manifold, put it in your mouth and suck as hard as you can, if you feel how the vacuum builds and STAYS as long as you suck the booster is ok, but if you hear whistling sound from booster and you can't hold the vacuum by suckin it's broken.
                      And yes, I'm serious.
                      Current:
                      • e30 gangsta
                        • 3877
                        ..... ok
                        • dude8383
                          • Jan 2005
                          • 10387
                          interesting...are there any other methods lol?
                          • Rocla
                            • 922
                            Yes a vacuum pump and gauge. Connect pump to booster hose, pump the vacuum and see if it holds, basicly the same thing as the sucking.
                            Current:
