I have an e30 m3 w/ an obdi converted m52 that was intended to be turbo'd but I am now considering the SC route. Has anyone hooked up one of the eaton's off the early 90s GM 3.8L's (pulley on the nose)? I imagine clearance is impossible and a centrifugal is the only option. In any instance, has anyone done a DIY SC job and what did you incorporate or learn you should have?
Eaton SC on M52?
If it helps, I am currently/temporarily running odbi software for the s50 by bmp w/ the injectors from the 3.0L (so injector pulse rates dont cause a major problem this is only to make it run while I am properly building this thing up to where it needs to be), m50 intake manifold, s50 throttle body, stainless free flow exhaust from headers back, 3.5 HFM (i know, i know, even with cams some say there are no gains, but I essentially was given it so i threw it on w/ everyones favorite, k&n cone filter), and most importantly NO AC OR FAN (electric aux fan, front mounted) which is valuable for this whole operation (can this pulley be used?). If i get an eaton roots s/c can it in fact be driven by ac pulley or utilize the open space? How can i get clearance? and most importantly, where do i start for engine management and MAP sensors?? Any informed help would be appreciatedLast edited by m52 e30; 07-10-2006, 06:59 PM.Comment
