Fuel Leak!
  • Midweste30
    • May 2014
    • 306
    Fuel Leak!
    I just recently started getting a fuel leak on the drivers side of my car near the fuel filter so I figured oh that must be bad so I'll replace that. I replace the fuel filter and the old brittle lines as well and the leak is still very prominent. It looks to be coming out of the top of the fuel tank just above the fuel filter? Any ideas? Luckily I will be dropping the rear subframe this weekend so I plan on dropping the tank then as well. Any ideas what it could be causing the leak? Also what should I look for when I drop the tank? Thanks!!!!
    1990 S50 Calypso-rot 325i
  • Todd Black 88
    • Oct 2007
    • 3449
    Pull the back seat and the access covers and take a look. It might be right there
    Originally posted by codyep3
    I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
    2001 silver/Blk 325 cabby. SOLD
    2002 325xit Sil/blk. SOLD
    2010 F650gs twin
    • Boris3
      • Apr 2007
      • 444
      There is a hard line that runs along the top of the fuel tank that can rust through, it will leak gas where you are seeing it and it can also pool on top of the fuel pump. You'll see/smell it when you pull the access covers.
      1990 325: track/racecar
      2003 330xi; project car
      2004 330i zhp: civilized car
      • Cephas
        • Apr 2012
        • 878
        These tanks are prone to rust pretty badly as well. You could have a small hole in the top of the tank causing this issue.
        We put a new tank in the track car a few years ago. Bought it for just under $200 on rockauto.
