so should i bleed my clutch?
  • FireFight
    • Mar 2012
    • 1367
    Hey guys, in my e30 i found the master was leaking alot and i replaced that and the slave. both where the highest quality i could get locally (i think FAG or FTE?)
    neither was bench bled, but where installed like i have done 1000 other times in other bmws, but i noticed the pedal seemed to be releasing a lot higher than usual. but it seemed firm and i let it be.
    the car sat for about a month and i drove it today to work and i rested my food on the clutch pedal in the parking lot and it went to the floor. I let up and pushed on it again and it was firm.
    i got down and looked at it and found very randomly if i push the softly it wont build pressure and will go to the floor, but this only happens 1 out of 15 times.
    But if i do firm hard presses and i haven't gotten it to the floor with out pressure.
    Im thinking there is still air pockets in the system, any ideas?
    WTB:m60b40 in PNW
    Zachary Ripley
    85 318i M50B25tu.
    92 525it 5 speed.
    80 244gl (m60 prepping).
  • AndrewBird
    The Mad Scientist
    • 11898
    Try bleeding it like this:
    • Dirty325ix
      • Sep 2012
      • 689
      I'm on my phone so I can't see that video but you could try that but
      Maybe you have a small Leak that released pressure as you had your foot on the pedal..it's basically a straight line up from the clutch master cylinder, so the clutch will bleed it self as long as the reservoir is full, you just have to press the pedal alot.
      • Das Delfin
        • Sep 2014
        • 2293
        That's super easy!
        • aegul44
          • Apr 2015
          • 396
          nice video
          Esquire E30 Build (87 325i Vert)
          Ultimate Tanning Machine
          • whodwho
            • Jun 2008
            • 1547
            That is typical of a master cylinder failure, normally on an old one but when pressing lightly on the pedal the fluid is passing by the cup/seal and the bore and the pedal will sink slowly and when pressing harder the pressure forces the lip to seal and function normally.
            It could be a nick in the seal or a score in the cylinder bore, I would check into a warranty.
            My M20 Frankenbuild(s)
            4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
            • FireFight
              • Mar 2012
              • 1367
              im gonna try to reverse bleed it, if that doesnt work looks like im taking it apart again
              WTB:m60b40 in PNW
              Zachary Ripley
              85 318i M50B25tu.
              92 525it 5 speed.
              • whodwho
                • Jun 2008
                • 1547
                My post all assumes that there isn't a leak, the fluid does stay full?
                Also just a note - the clutch will self bleed, there is a small hole to the reservoir that as the piston moves a small amount of fluid(with air if any) will be pushed back to the reservoir every push of the clutch. You can basically bleed it with short strokes of the clutch pedal and any air is the system will make it back to the reservoir.
