Every once in a while my car will randomly cut out....or if I am stopped at a light idling it sometimes turns off... This happens very rarely but like I said it happens and it is very annoying. The idle control valve is very new so I have kind factored that out. Anyone else have any ideas! Thanks
M20 randomly cuts out!
Tags: None
vacuum leaks... or a real far fetched idea...
Maybe water has leaked thru your passenger side blower vent (from the outside air to the cabin) and made it's way into your ECU and corroded the circuits to the point that the fuel and/or spark is inhibited.. If it gets worse, it pays to check out your ecu circuit boards.. It happened to me..fuckin wierd.. never would have thoughtRecent Rebranding!!
E30 SM62/S62
E30 M60 V8
E30 M30 Big 6!
Instagram.com/garageaholic
Youtube.com/garageaholic -
This same thing happened to an e36 at workOriginally posted by M3fan4eva
Originally posted by cabriodster87"Honey? What color is this wire? Is it the same as that one? Are you sure? I don't believe it. OK, it works. Thank you sweetie."Originally posted by Kershawi've got a boner and a desire to speed.Comment
haha, wierd huh?Originally posted by Mike325This same thing happened to an e36 at work
The guy ended up scraping off the corrosion CAREFULLY with a mild wire brush and it started back up...I thought it was funny, but he put the ECU in a plastic bag and tried to seal it as best as he could... and then tie-wrapped it and called it a day...$250 fix (labor to find the problem)Recent Rebranding!!
E30 SM62/S62
E30 M60 V8
E30 M30 Big 6!
Youtube.com/garageaholicComment
