wats the best way to get that stuff out? it came out without a breeze on my late model e30. its seems to take for ever to remove it on my 87. is there any speciay to get that shit out?
Trunk Sound deading Material
Tags: None
from the two cars ive stripped, i can tell you there is no good way
the first time was a PITA and took forever with a paint scraper in a 100 degree garage
the second was comparativley easy with a prybar
best bet is to wait for a hot day and use a strong flat blade, the wider the better, that way you can get underneath it
maybe use a hammer too, but just be careful
it seems like it takes forever, but youll find your rythm -
use a exacto knife to cut a crisscross pattern in the tar. Then cush up dry ice and cover the sound deadening stuff and let it sit. You'll want to put a towel over top to insulate it so the dry ice does not evaporate really quickly. After a few hours it should peal up. You can buy dry ice at Kroger, good luck that job sucks. What ever tar remains go at with a torch and a scraper, if you use this method make sure you wear a mask you don't want to breath this stuff in.Comment
