Car shuts off randomly, won't start until engine is cold
  • dnguyen1963
    • Nov 2011
    • 2651
    Originally posted by Kershaw
    Things expand when warm, usually vacuum leaks are present when cold, but not warm. That doesn't make sense to me. Also, the fact that it doesn't even try to start at all, like no cranking, means that it's probably not a vacuum problem. Sounds more like a grounding issue. The hot/cold thing doesn't make sense though.
    The only thing I can think of is heat soak. A hot wire will have a greater resistance than a cold wire. So it may be that something is getting funky when the hot engine heat soaks the engine bay.
    Not always true...when things expand, vacuum leaks can develop at places like the throttle body or valve cover.
    • LounsRacingInc
      • Mar 2015
      • 61
      You are both correct, vacuum leaks could be caused by heat or cold (although heat is not as common as cold) but if you don't have switching on the negative side of the coil the issue is not vacuum related, its electrical and has to do with a sensor or wire that is effected by heat
      1987 LuxorBeige 325 4 door (daily)
      1988 Zinnoberrot 325 4 door
      1984 and 1986(7)? Parts cars
      • LounsRacingInc
        • Mar 2015
        • 61
        Originally posted by D_bender
        Ok. Both sensors are good, Ignit ion coil does light up. I just put in a new coil, Cap and rotor, and crank sensor
        Does it light up and stay lit? or does it flash when cranking, you should see a very distinct flashing while cranking
