Dyno Results
    Dyno Results
    Now, my A/F is high (15:1 in the top end at WOT)
    But some of the other guys there were getting way off readings (lean) too
    This is a tail pipe gas spectroanalyzer, which can also be thrown off by a clogged cat.
    I figure I can get another 2whp out of it with the Supersprint installed.
    Overall, Im very pleased when compared to last year's results (blue)
    Does anyone else have any dyno readings with A/F on them with a JimC chip and without so I can compare the two?
    Even if the A/F was off on the dyno, I would like to begin tackling what could be a possible problem. I figure I'll start at the fuel filter and work my way to the injectors
    BattleWagon|1996 GT Vertigo
    Not a bad outcome for a 200k + engine.
    - Sean Hayes
      to say the least
      175bhp peak corrected @ 15%
      someone asked me if it was a turbo because of the big ramp at 3500. He's not used to seeing 'cam lag' in this world of variable cam timing :D
        what variable cam timing?
        BEERTECH
          VANOS
          he's used to M50TUs and up
          We rely on an 'on cam' power delivery rather than a variable one. Traditional power :)
          Im most happy with the smoothed out line.
            fancy talk confused me :P
            BEERTECH
              Lucky for you Jared I have my dyno of my stock M20 w/ JC chip 8) The A/F is a little high, I'll take a picture of the graph tomorrow, but for now the ratio is never below 13.8.
              -Ted
                yeah, most of the way its high 13s/low 14s
                but then you can see at around 6000 it leans out to 15
                  Repost the picture, its X.
                  But my guess is 148.75 with 15% drivetrain loss?
                  This is your m20b25 dyno numbers?
                  Not bad, what do you have done to it?
                  95' M3.
                  90' 325i Turboed.
                  87' 325eS Fixed.
                    my website just went down...
                    so all my images will be back when Comcast fixes that...
                    yeah, its 148.6whp
                    right now I just have software
