How long will a ISV last
  • ecsk
    • Nov 2011
    • 106
    My 325i has surging idle, as usual I checked air leak, throttle switch under the throttle body, they are all good, then electrical test shows the ISV is out of spec. I have a new one in part bin, swap it in, all good.
    The ISV that goes back are very new, about 2 years old. Am I just unlucky to have a bad one or it's the usual life span, it's a over US$200 part !!
  • AndrewBird
    The Mad Scientist
    • 11897
    Could just be gunked up. A bit of carb cleaner sprayed into it and then shaking it back and forth will usually free it up. That is, unless the coil is burnt up.
    • ecsk
      • Nov 2011
      • 106
      Cheers, done that already .
