vert 325i parts fit in 325es?
  • wolverine_sr24
    • Nov 2015
    • 68
    hello, so my 325es needs a driveshaft, suspension and body parts
    so I found a 325i vert with 175k (working odometer) for sale as parts for only 1000. only thing wrong is the rear trunk is smashed.
    so my question is, will the driveshaft fit if im dropping in the motor tranny and diff? im thinking about doing a full swap over and making the es a 325i.
    |OO=[||][||]=OO|
    /____ALPINA____\
    300lbs Deadlift
    1987 325es 2.7i chipped
    1992 325i : SOLD
    2004 e46 M3
    2007 e90 M3
    • 37828
    For the driveshaft, if the vert is a 88+ you'll just need to swap to a early model CSB.
    The suspension pieces will be identical.
    The fenders and doors will not interchange.
    Classic BMW Specialists
    Grover Beach, CA
    www.BimmerHeads.com
    • wolverine_sr24
      • Nov 2015
      • 68
      really? not the front fenders?? dang i would of never guessed
      |OO=[||][||]=OO|
      /____ALPINA____\
      300lbs Deadlift
      1992 325i : SOLD
      2004 e46 M3
      2007 e90 M3
      • Das Delfin
        • Sep 2014
        • 2293
        vert front fenders are different from hardtops.
        You can use the 325i head, intake manifold, injectors etc in your car. Would be worth it for a 2.7i stroker build along with suspension if you part out the vert specific stuff
        • wolverine_sr24
          • Nov 2015
          • 68
          i think I want to go with the 2.5 motor and start a build from there.. but is the 2.7 no different then the 2.9i? if not i guess ill do that. will the hood, front aluminum bumper, and the little body piece beneath the grill fix perfectly?
          |OO=[||][||]=OO|
          /____ALPINA____\
          300lbs Deadlift
          1992 325i : SOLD
          2004 e46 M3
          2007 e90 M3
