Hi all,
I´m having problems with my speed-o-meter.
sometimes it drops to 0 while driving
when i gently tap the cluster most of the times it jumps back to the speed i´m doing, and sometimes it jumps for a moment and then drops again back to 0.
sometimes it works perfect without dropping, and sometimes it doesn´t work at all...
I recently swapped my old cluster with this new 318is cluster, and afterwards i´m having the problems.
myself i think it´s mostly because of a bad elektrical connection between the meter and the back-plate. i already tried to tighten up the connections but still no real succes.
could it be that i need to resolder the backplate? i´ve heard these solders break of old age, or can something else be the problem?
i dont think it´s the speed sensor on the diff, because the speed meter reacts when i tap on the cluster.
Perhaps somebody here had the same problem in the past and knows a solution?
Thanks in advance.
Thanks in advance.
