so yea ever since i replaed my timing belt , nothing but weird shit has happened to me.i went to fill the resevoir bottle up with 50/50 mix and then i started the car up . my understanding is the water pumpr\ would pull the coolant out of the resevoir and into the system , so i ran the car for about a minute and checked the resevoir. empty (this is good ..meens that collant is in the system) so i receaded to fill the bottle back up and then ran it again. i then checked the bottle and it was still full so i was like cool, its done. Well i went out for a drive and the car is hickuping and bogging like crazy and at idle the exhaust note is more of a pulse than a steady hum, and the motor is idling at like 500 rpms !!! but thats another problem. any ways while i was out the temp gauge just started climbing up to the red . so im hurrying home and pull in right as the needle hits the red zone and i cut the motor off and coast into my garage. i undid the resevoir bottle and it had pressure in it. and its full. so i was like (you fucking retard you didnt bleed the system). i waited for the car to cool down and then i started bleeding it. cranked it back up and then cracked the bleeder nut off and watched bubbles come out then a steady jet stream of coolant coming out of the bleed hole. so i was like cool its done..... nope still over heating and no fan coming on and the tubes still feel empty like they have no coolant in them..
i was wandering what you guys think i should do and if you guys had access to a bently coolant section and trouble shoot, could you scan it and email me it. also as far as the sputtering and what not... all the [plug wires where labled when i took them off to there corresponding position on the cap , and that arrow looking plastic piece that is under the cap with 3 allen screws holding it in can only go on one way right???
car has new fuel filter
new spark plugs
new gas
clean air filter
just things that have already been ruled out as far as the jick up and sputtering
thanks guys and sorry for being so stupid!!!
new spark plugs
new gas
clean air filter
