People with ABS need some pictures
  • Z2TT
    • Feb 2014
    • 51
    Hi Guys.
    For those guys who have ABS in their E30's I need to know which hole in the chassis the ABS Sensors run through. Mine run through a big hole and have no grommet.
    So I bought new abs sensors thinking they have some big grommet on there but the grommet is just about 1 or 1.5 centimeters in diameter.
    Would you guys please send me some pictures on what hole your ABS Sensors, Brake Sensors and other things protrude through in the holes around the strut towers as I'm putting a car back together and a bit lost and unsure.
    I don't know whether there should be a grommet there, as my wiring was very aged, or if its poked through the wrong hole to begin with.
    Thanks.
  • wodcutr
    • Apr 2009
    • 2193
    The fronts just go through the large hole with no grommet. The sensor wires attach to the upper strut housings and are held in place by a multi fingered metal piece that is welded to the strut. The little rubber grommet you are referring to slips into those fingers.
    The difference between porcupines and BMWs is that porcupines have the pricks on the outside!
    • roguetoaster
      Biggus Tippus
      • 7830
      If you'd like a grommet at the body hole just measure it, order one of the correct size off of the following link and cut a small round hole in it
      • DirtyTh3rty
        • May 2015
        • 101
        Mine is just open holes also no grommets
        88' BMW 325is - Daily
        • Z2TT
          • Feb 2014
          • 51
          Do the brake pad sensor wires run through the same hole as the ABS?
