Wire across top of rear deck
  • mcm185
    • May 2013
    • 132
    Ok so I'm putting my e30 m3 back together and I reinstalled the wire harness and I labeled it pretty well. However I have two wires that I'm not sure where they hook up to.
    1. Originally ran across the top of the rear deck by the speakers from the driver side to the passenger side, it was UNDER the heat/sound insulation when I pulled it out. Where does it go? I don't think it was hooked up to anything but I'm not sure what it's for. It is part of the main wire harness not the stereo wiring.
    2. The other wire is a 3 pin female connector that I runs in the the trunk, down the passenger side. It has a small rubber grommet on it but I'm not sure what it was hooked up to, perhaps the trunk central lock system?
    I will post a pic later but any help appreciated.
  • StereoInstaller1
    GAS
    • 22679
    1. Speaker and defrost both run across
    2. Likely the 3rd brake light circuit
    GL!
    Luke
    Closing SOON!
    Thanks for 10 years of fun!
    • peterman
      • Feb 2015
      • 173
      1. Rear defroster probably. does it have a female crimp connector on the end of it?
      2. no idea
      • AndrewBird
        The Mad Scientist
        • 11897
        #2 might be for the gas door actuator.
        • StereoInstaller1
          GAS
          • 22679
          Gas door actuator wiring is in with the taillight wiring
          Closing SOON!
          • rcsoundn1
            • Nov 2012
            • 3361
            I love a good who done it
            • mcm185
              • May 2013
              • 132
              Thanks guys got it figured out.
