Help with no start issue
  • jplettuce
    • Oct 2014
    • 47
    Problem happened a couple days ago and have been trying to fix it. Car is a 1991 318is with an us s50 swap and it won't start, I never heard the fuel pump when I tried to start it so I figured that was the problem, I replaced it with a tre fuel pump and I know I made good solder connections to the pump assembly and it is wired and installed correctly, however I do not hear it priming and it is not getting power and car still has no fuel, I do not know which of these relays is the fuel pump relay and if someone could help, I bought it a week ago and would love to enjoy it some more.
    EURO URO UR BROKE
  • DirtyTh3rty
    • May 2015
    • 101
    Pretty sure its the blue one
    88' BMW 325is - Daily
    • jplettuce
      • Oct 2014
      • 47
      ok any more things i need to check?
      EURO URO UR BROKE
      • jplettuce
        • Oct 2014
        • 47
        i figured out that my new fuel pump needs 12 volts to even work and im only getting 10 volts from the connection to the fuel pump will check all grounds and try again
        EURO URO UR BROKE
        • jplettuce
          • Oct 2014
          • 47
          Got a new battery and fuel filter and got the pump running, BUT car is leaning out almost as soon as I start it, there is oil and gas in the intake manifold and I don't know what to check next and need advice.
          EURO URO UR BROKE
          • dnguyen1963
            • Nov 2011
            • 2651
            Your injectors are most likely leaking.
