Hi everyone,
This is the most stumped I've been on an e30 before. My 92' e30 convertible always used to start on the first crank. Over the course of 3-4 weeks it started taking 2 or 3 times to start, then it finally ceased firing altogether.
Initially cold start fluid helped, but then the CPS failed causing no fuel or spark. I replaced the CPS and it started again with cold start fluid, but won't run for more than a few seconds b/c it appears to not be getting fuel.
The battery is strong. I have tested everything on the ignition side except the distributor, but assume this works since the engine fires with cold start fluid. Without cold start fluid, the engine does not fire or even cough for that matter. I have replaced the fuel pump, fuel filter, fuel pressure regulator, spark plugs, main relay, and fuel pump fuse. I have used two ECU's to test the wiring and it all seems to be working with the exception of the 'air conditioning on' test. I have jumped the fuel pump relay (I have not replaced it though) and the engine still won't start. The fuel pump is getting 12 V. I was initially getting a Lambda Control 1 check code. That went away. Now I get no fault code reading b/c the one other ECU test that doesn't work is the 'idle position' on the TPS. Without the TPS working, it doesn't register that I am hitting the gas pedal 5 times. There was a period that the TPS worked fine and the car still wouldn't start, during which time I got 1444 (no fault) on the stomp test.
In short, I am not getting fuel and do not know if it is a mechanical or electrical failure (or both). And the injectors click via the ECU test, so I assume they haven't all failed. Also worth mentioning is that some of the clicking noises from the manual ECU test do not occur when the car is on ignition 2.
Anyone have ideas on how to fix this?
