My question is does the fusible link in my control module keep coming apart because my actuators are bad? or is it something else, because as far as I can tell there are no shorts in the wiring anywhere. I can not figure out what is causing the red/black wire to run too much voltage through it then blowing the fuse.
I am hesitant to install new actuators in the car if the the electrical side of things isn't going to work and the fusible link is just going to keep coming apart. I am ok with the lock cylinders not working as I just want to get it to the point where I can install keyless entry. Any answers, advice or insight would be greatly appreciated! Thanks in advance!
